1991 Chevy Pickup Block Heater Leak Fix
TBRENNAN
1991 Chevy Pick-up 6 cylinder engine
There is a plug in the bottom of the enigine near the oil filter with a wire or hose coming out of it. The plug is pouring coolant out of it. What is this plug?
Apr 8, 2007 at 1:31 PM
BOOTDOG
  • 665 POSTS
that would be a freeze plug with a heater element to warm the coolant before you start it. the wire is mainly for extremely cold temps up north. depending on where you live, (i.e.) the south, you can replace it with just a plain freeze plug with no wire connection and tie the wire out of the way. however, if you live up north, replace it with the same freeze plug heater element.
Apr 8, 2007 at 2:49 PM
TBRENNAN
[quote:cd2f5109c9="bootdog"]that would be a freeze plug with a heater element to warm the coolant before you start it. the wire is mainly for extremely cold temps up north. depending on where you live, (i.e.) the south, you can replace it with just a plain freeze plug with no wire connection and tie the wire out of the way. however, if you live up north, replace it with the same freeze plug heater element.[/quote:cd2f5109c9]
Thank you that makes sense. I live in Alaska so I think I will need the heater element. :D
Apr 8, 2007 at 3:15 PM
  • 75,988 POSTS
[quote:ae62c85747="tbrennan"][quote:ae62c85747="bootdog"]that would be a freeze plug with a heater element to warm the coolant before you start it. the wire is mainly for extremely cold temps up north. depending on where you live, (i.e.) the south, you can replace it with just a plain freeze plug with no wire connection and tie the wire out of the way. however, if you live up north, replace it with the same freeze plug heater element.[/quote:ae62c85747]
Thank you that makes sense. I live in Alaska so I think I will need the heater element. :D[/quote:ae62c85747]
It tells me something you're new there-comeback and give Mr. Bootdog a feedback and vote he deserves it. Better give that alaskan spirit or don't come to Russian River for that combat fishing or Seward for 4th of July lol.
Good Luck and Happy Easter
Apr 8, 2007 at 5:47 PM
Suggested Repair
The leaking plug is a freeze plug with a block-heater element. Because the truck is used in Alaska, replace it with the same freeze-plug heater element rather than a plain freeze plug.
Conversation Summary
The owner of a 1991 Chevy pickup with a 6-cylinder engine reported coolant pouring from a plug near the oil filter that has a wire or hose attached. An expert identified it as a freeze plug with a heater element used to warm coolant before starting in extreme cold. The owner lives in Alaska and plans to replace it with the same heater-equipped freeze plug.
