2005 Dodge Neon rear turn signals, break lights and rear ha
2005 DODGE NEON
93,286 MILES • 4 CYL • 2WD • AUTOMATIC
RIDDLA02
I have a 2005 dodge neon and I'm having an issue with my rear turn signals, break lights (including center brake light) and rear hazard lights. None of those lights are working. It first started out on the passanger side rear turn signal and then when I went to go check if it was the bulb the other side and center went out. Both bulbs seem fine and the filament is not burnt out or broken. One side came on for a bit but then hasn't worked since. I've checked all the fuses and they all seemed fine. Also the ground wires seemed connected. My check engine light came on for a day but by the time I was able to go get it checked it went away but the lights still didn't work. I would appreaciate any advise as to what the problem may be. Thanks in advance.
Feb 11, 2010 at 5:32 PM
2CARPRO JACK
  • 11,533 POSTS
I would normally o to tehturn signal switch, but since the 3rd brake light isnt working, go to the underhood fuse panel and check fuses 15, 23 with a test light. then go back under the dash and double-check fuse 1, 15.It still may be the turn signal switch, it looks like the hazard, turn and flasher are all integrated into one unit, start with the basics
Feb 12, 2010 at 12:04 AM
