2002 Dodge Neon Headlights Out
JAMIENDAVE2006
[i:fee361beb5]A few months back, we replaced the headlight switch in the steering column of the car, the switch that controls the headlights, the turn signals, foglights, and the highbeams. this morning when we started the car, the headlights and the fog lights won't come on. the high beams come on, and the turn signals work. the fuses were checked and are all fine, what else could possibly be wrong??
the car is a 2002 dodge neon and has 30000 miles on it
jamie[/i:fee361beb5]
Dec 20, 2006 at 3:19 AM
MATHIASO
  • 1,209 POSTS
Typical problems with headlight system are , no left or right lights, no light, dim lights ,or very bright light.
the problem we have here is: no lights
if the high and low beams are out on both sides of the car or truck, look for a problem in the main power source.
The proble may be failed fusible link, relay or headlight switch.
one easy method of testing the fusible link is to remove the relay and test pins 1 or 3 to ground with a test light or meter.
there should always be 12 VDC on these two pins is the battery is connected and the main fusible link is good.
Test the relay with your fused jumper leads.
the relay should display 12 VDC
Dec 20, 2006 at 4:42 AM
Suggested Repair
Check the headlight power feed, fusible link, and relay, and recheck the recently replaced headlight switch. With the relay removed, pins 1 and 3 should have 12 volts to ground if the fusible link is good; also test the relay with fused jumper leads.
Conversation Summary
The owner of a 2002 Dodge Neon says the headlights and fog lights will not come on, although the high beams and turn signals work and the fuses are good. The steering-column switch controlling those functions was replaced months earlier. The expert says a loss of lighting on both sides can involve the main power source, a failed fusible link, relay, or headlight switch, and suggests checking for 12 volts at relay pins 1 and 3 and testing the relay.
