2001 Dodge Neon factory alarm
CHRISTIEPRATT
  • 2001 DODGE NEON
  • 4 CYL
  • FWD
  • 145,000 MILES
My car beeps like I put on the alarm. (Factory) I don't have the control. Sometimes the door locks don't work. And when the alarm goes off the trunk pops even when im driving. Does anyone no where the alarm wire is so I can cut it or something?
Wednesday, June 11th, 2008 AT 9:57 PM
JANDAFIELDS
It sounds like whoever had this car before you took it to their dealer and had the factory alarm activated. The trunk popping means that when the dealer activated the alarm, they used the body code of a PT cruiser instead of a Neon. It is possible that their mistake can not be undone without a new Keyless Entry module. Your dealer has the only tool (DRB-III Scan Tool) available for making changes to this area of your car. This is not anything you can do yourself. There is no wire you can cut to deactivate the alarm. You could, however, cut the wire to the trunk release.
Tuesday, June 24th, 2008 AT 2:00 PM
