1998 Dodge Neon Car Alarm Problem
1998 DODGE NEON
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
NANEY98
HELP me please...My car had a car Black Widow car alarm when i purchased it. The previous owner gave me the remote controls and for a long time it worked fine. One day the alarm remote would just not disengage the alarm. I tried changing the battery in it but nothing. The alarm had a starter cutoff on it so i cant start the car. The engine doesn't turn, you only hear the gas line spray but the car will not turn on. I took i to the mechanic and he told me that i should disconnect my car battery to reset the alarm system so it would turn on. I did this and For a while it worked fine but now it just won't start. Can a regular mechanic fix this? Who can I go to in order to get the alarm taken off so i don't run into this problem anymore? I don't even need the alarm!! PLEASE HELP! I really need my car to get around for work and for the last month i've been carless! I'm so lost about what to do?!
Jul 23, 2009 at 1:52 PM
BMRFIXIT
  • 19,053 POSTS
Your local auto repair shop should be able to help you in disconnecting the alarm and restoring the wiring to its original positions
I would also suspect that you may have a starter problem if disconnecting the battery worked for a while and know it does nt
just a suspicion and need to have it looked at \
good luck
Jul 23, 2009 at 3:26 PM
