2000 Dodge Neon
TMUNYON
  • 2000 DODGE NEON
Electrical problem
2000 Dodge Neon 4 cyl Two Wheel Drive Automatic
I HAVE AN ERROR CODE FOR A FAULTY OXYGEN SENSOR IN BANK 1 SENSOR 2 I KNOW IT IS AFTER THE CAT BUT WHICH SIDE IS BANK 1
Saturday, December 13th, 2008 AT 9:08 AM
MORTICAR
  • 46 POSTS
There should only be two o2 sensors on the car. One before the cat and one after. The one you want to change is the one after the cat convertor. Theres only one you cant mess up. The banks have no meaning when you are under the car. Just look for the o2 sensor in the exhaust pipe and change it. You will need a special socket for the sensor available at any parts store. Hope this helps! MORT
Saturday, December 13th, 2008 AT 1:16 PM
