1998 Dodge Neon radiator and starter
MICHELLEMO87
Electrical problem
1998 Dodge Neon 4 cyl Automatic 150054 miles
Over the past month and a half, my car has overheated every week. A week and a half ago I took it to the mechanic and he changed 2 hoses, my thermostat and the gasket for that. A few days ago, i parked in my driveway and steam started rolling out of the front of my car. My radiator died. Yesterday, we bought a brand new radiator and replaced it. We went to turn the car on and it wouldn't turn over. The electricity came on, however, my turn signal was mysteriously blinkiing away and would not turn off. Even when the key was in the ignition enough to make the beeping sound when the door is open, the turn signal was giong. I need help. I wasn't having any problems at all with my starter or my turn signal before my radiator went bad.
Aug 4, 2008 at 4:11 AM
BMRFIXIT
  • 19,053 POSTS
did u disconnect the battery
I would say check the alarm system
Aug 5, 2008 at 2:02 PM
MICHELLEMO87
Yes, We did disconnect the battery. If it is connected , my left turn signal blinks. It stops after a few minutes but when you put the key in the ignition it starts again. How do i check the alarm?
Aug 6, 2008 at 4:09 AM
BMRFIXIT
  • 19,053 POSTS
try this :
disconnect the battery again
turn key into ON position
reconnect the battery and then try to start
and or look for small on off switch (after market ) usually its under the steering wheel area driver side
Aug 6, 2008 at 9:26 AM
MICHELLEMO87
thank you so much! i cant believe i didnt realize it before. now that my car has been sitting in my driveway for almost a week, i feel kinda stupid. it did work by the way!!
Aug 7, 2008 at 12:52 AM
BMRFIXIT
  • 19,053 POSTS
We all sometime over look the smallest things
I’m glad all good for you
happy driving
Jack
Aug 7, 2008 at 12:44 PM
