radiator drain plug
1998 DODGE NEON
12,500 MILES • 4 CYL • 2WD • AUTOMATIC
TURBOTAIL
  • 30 POSTS
I have no idea how to drain my radiator and add antifreeze. Where's the plug?? Help! Thanks
Jan 10, 2010 at 9:50 AM
REMOVAL: Draincock
https://images.2carpros.com/forum/automotive_pictures/12900_drainplug_1.gif
1.Turn the drain cock stem counterclockwise to unscrew the stem. When the stem is unscrewed to the end of the threads, pull the stem from the radiator tank. INSTALLATION: 1.Push the draincock assembly body into the tank opening. 2.Tighten the drain cock stem by turning clockwise to 2.0 - 2.7 Nm (18 - 25 inch lbs.) .
Jan 10, 2010 at 10:31 AM
