2003 Dodge Neon Hose coming from coolant system
2003 DODGE NEON
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
WILLIEMAYS2000
One of my hose pop off my coolant system, when I put it back how can I make sure it don't pop off and where do the two hoses coming from the coolant reservior go?
Jan 14, 2010 at 10:43 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
When you replace the hose, use a good radiator (worm) clamp to tighten the hose in place. As far as the 2 hoses to the resivour, one will go to the radiator (right below the cap) and the other is most likely an overflow that will point down incase there is too much coolant in the jug.
If you have other questions, let me know, and thanks for using 2carpros.com.
Jan 14, 2010 at 6:25 PM
