1998 Dodge Neon engine will crank but will not start
AJGILLIAM
  • 1998 DODGE NEON
Engine Mechanical problem
1998 Dodge Neon 4 cyl Two Wheel Drive Automatic
asked same question 3 weeks ago but to summarize what I have checked and replaced.
Car just died pulling into parking spot. Checked fuel pressure ok. Ck'd spark and found good spark on 2 & 3 cyl, no spark on 1 & 4. Borrowed scanner and no codes( battery had went dead.) Replaced coil pack still no spark on 1 & 4. Ck'd for pulse at coil harness and 2 & 3 had pulse, no pulse on 1 & 4. Put old coil pack back on. Removed pcm connectors and checked wires from pcm to coil pack, had continuity on both wires. Replaced pcm and still no spark on 1 & 4. Replaced crank sensor still no spark 1 & 4. Ck'd continuity on wires from pcm to crank sensor OK. Ck'd for 8 volt current on orange wire to crank sensor ok. Swapped out ASD relay and no start. Need some fresh ideas on what to do next.
Tuesday, February 10th, 2009 AT 3:08 PM
DAVE H
  • 13,384 POSTS
Hello. Thanks for the donation. Much appreciated
Is the PCM throwing any codes now you have battery charge and have been cranking? It should be picking up on where the fault lies? Can you check CMP sensor & wiring !
DISTRIBUTORLESS IGNITION SYSTEM (DIS)
DIS eliminates mechanical ignition components that can wear out. PCM has complete ignition control and uses a coil pack, CMP sensor and CKP sensor to control ignition timing. CMP sensor reads slots in cam timing sprocket. PCM uses this information along with information from CKP sensor to determine if fuel injectors and ignition coils are properly sequenced for correct cylinders.
Basic timing is determined by CKP sensor position and is not adjustable. One complete engine revolution may be required for PCM to determine crankshaft position during cranking.
Molded ignition coils are used. Each coil fires 2 paired spark plugs at the same time. One cylinder is on compression stroke and other cylinder is on exhaust stroke.
TEST TC-1A: NO CAM SIGNAL AT PCM
NOTE:For connector terminal identification, see CONNECTOR IDENTIFICATION. For wiring diagram, see WIRING DIAGRAMS article.
Using scan tool, erase DTCs. Attempt to start engine. If engine will not start, crank engine for at least 15 seconds. Using scan tool, read DTCs. If NO CAM SIGNAL AT PCM returned, go to next step. If NO CAM SIGNAL AT PCM did not return, got to TEST TC-1C.
Turn ignition off. On 2.5L, go to next step. On 2.0L and 2.4L, disconnect Camshaft Position (CMP) sensor connector. On 2.0L and 2.4L, CMP sensor is located on end of cylinder head. Go to step 4).
On 2.5L, disconnect 6-pin distributor connector. Camshaft Position (CMP) sensor is located inside distributor. Go to next step.
On all models, inspect connector for damaged or pushed out terminals. Repair as necessary. Perform TEST VER-2A. If connector is okay, go to next step.
Using an ohmmeter, check resistance between CMP sensor connector (harness side) ground circuit and ground. See CMP SENSOR CONNECTOR WIRE IDENTIFICATION table. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open ground circuit to harness splice. Perform TEST VER-2A.
Turn ignition on. Using a voltmeter, check voltage of CMP sensor connector (harness side) 8-volt supply circuit. See CMP SENSOR CONNECTOR WIRE IDENTIFICATION table.
If voltage is more than 7 volts, go to next step. If voltage is 7 volts or less, repair 8-volt supply circuit. Perform TEST VER-2A.
Turn ignition off. Connect a jumper wire to CMP sensor signal circuit. See CMP SENSOR CONNECTOR WIRE IDENTIFICATION table. Turn ignition on. Using scan tool, note CMP sensor signal state. While observing scan tool display, tap other end of jumper wire to CMP sensor ground circuit. See CMP SENSOR CONNECTOR WIRE IDENTIFICATION table.
If CMP state changes, go to TEST TC-1B. If CMP state does not change, turn ignition off. Disconnect PCM connectors. Using an ohmmeter, check resistance of CMP sensor signal circuit between CMP sensor connector (harness side) and PCM connector terminal No. 33 (sensor ground). See CMP SENSOR CONNECTOR WIRE IDENTIFICATION table and POWERTRAIN CONTROL MODULE WIRE IDENTIFICATION table. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open CMP sensor signal circuit. Perform TEST VER-2A.
Using an ohmmeter, check resistance between CMP sensor connector (harness side) signal circuit and sensor ground circuit. If resistance is 5 ohms or more, go to next step. If resistance is less than 5 ohms, repair signal circuit for shorting to sensor ground circuit. Perform TEST VER-2A.
Using an ohmmeter, check resistance between CMP sensor connector (harness side) signal circuit and ground. If resistance is 5 ohms or more, go to next step. If resistance is less than 5 ohms, repair signal circuit for shorting to ground. Perform TEST VER-2A.
Using an ohmmeter, check resistance between CMP sensor connector (harness side) signal circuit and 8-volt supply circuit. If resistance is 5 ohms or more, replace PCM. Perform TEST VER-2A. If resistance is less than 5 ohms, repair signal circuit for shorting to 8-volt supply circuit. Perform TEST VER-2A.
ApplicationWire Color
CMP 8-Volt Supply Circuit
Avenger, Sebring Coupe & Talon (1) Yellow
Breeze, Cirrus, Sebring Conv, Stratus & NeonOrange
CMP Signal Circuit
Avenger, Sebring Coupe & Talon 2.0LDark Blue/Red
Avenger & Sebring Coupe 2.5L(1) Brown
Breeze, Cirrus, Sebring Conv, Stratus & Neon (1) Tan/Yellow
CMP Ground Circuit
Avenger, Sebring Coupe & Talon (1) (2) Black/Dark Green
Breeze, Cirrus, Sebring Conv, Stratus & Neon (1) (2) Black/Light Blue
(1)On 2.5L V6, camshaft position sensor wire is located at distributor connector.
(2)On 2.5L V6, ensure sensor ground is tested, not distributor ground.
PCM Terminal No. 33 (CMP Sensor Signal Circuit)
F24S & FJ22 Bodies
2.0LDark Blue/Red
2.5LBrown
JA, JX & PL Bodies
Tuesday, February 10th, 2009 AT 6:16 PM
AJGILLIAM
  • 5 POSTS
Rechecked for codes and no codes found. Will check cam sensor but thought cam sensor was related to injectors and not so much for ignition spark. Will check it anyway.
Thanks, Doug
Tuesday, February 10th, 2009 AT 8:09 PM
TBEN8336
Hi! I am currently having all the same problems that you had exactly and have done everything as you have said. I am just curious as to whether you found what was wrong and if you could possibly let me know what you did to fix it? Thanks so much!
Friday, September 25th, 2009 AT 8:18 PM
DAVE H
  • 13,384 POSTS
Check/replace the CMP (camshaft position) sensor !
Sunday, September 27th, 2009 AT 4:37 AM
JERRY-BROWNING
Had the same broblem with a 99 dodge neon. Replaced the crank senser still didnt start was thinking about the crank senser and the magnetic fild and the battery was not putting out anuff amps charged the battery and it started. Thinks for the help guy's
Saturday, July 4th, 2015 AT 1:32 PM
JERRY-BROWNING
Hi my name I jery and I have a 1999 dodge neon it had a fireing broblem it would turn over but it didnt start so I changed the crank senser and still nothing. So the next thing was to chang was the cam senser it took all the idle broblem and the miss fire out dont forget to charg the battery. Thinks guys.
Sunday, July 5th, 2015 AT 9:09 AM
