I have a 98 neon coupe that had a 2.0 sohc. the timing belt broke. I had a crashed 2.0 dohc car so I swapped the motors. It started right up when I was done with the swap. I had it idling for around 20 minutes. As it was idling it just died like someone had turned the key to off. Now it wont start back up. It just cranks. I'm a bit lost since it was running fine for 20 minutes with no check engine light on. where should I start?
Feb 7, 2016 at 7:11 AM
