1997 Dodge Neon Will not start
125,000 MILES • 4 CYL • FWD • AUTOMATIC
TRAVISTADRUSSELL
Sometimes the car will not start, not even turn over. It ONLY happens after it's been drivin for 30 mins or longer. After drivin I will turn car off. If I go back to start it after it sits there for more than 10 mins it will not start. It usually take 3 or 4 hrs for it to start again. I have taken it to several shops. They said it's not the starter. Some say it's the coil. But there not sure.. Can u help?
Oct 8, 2008 at 1:00 PM
LEGITIMATE007
  • 5,121 POSTS
your gonna have to check the spark and the fuel after the vehicle has warmed up to see if you can catch it acting up, I mean it could be several things, when its cold it will be fine but when its hot , some circuits may stay open or closed and not work properly. also you may want to check the mass airflow sensor and the engine coolant temp. sensor. usually the engine light will come on when these two are bad, but at this point it looks like the problem is intermittent thus causing the engine light not to illuminate. I'll send you a couple of video links that show you the easy way to check your spark and fuel. then we can take it from there.
Oct 8, 2008 at 2:53 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
