1997 Dodge Neon weird oil leak
COBRA6910
  • 1997 DODGE NEON
Engine Mechanical problem
1997 Dodge Neon 4 cyl Front Wheel Drive Automatic
me and my uncle just changed the head gasket on our 1997 neon and we put it all back together now there is an oil leak coming from what looks like behind the crank pully and we cant figure it out got any help
Friday, October 31st, 2008 AT 3:43 PM
IMPALASS
  • 3,112 POSTS
Hello - If I understand your question correctly, you now have oil leaking from the seal that goes around the crankshaft? Is it behind this wheel in the pic? This is the crankshaft seal, inside the timing cover. I wouldn't imagine the head had anything to do with that. These leak. Not sure what your mileage is but if you are at about 100000 then this is probably due to go.
Saturday, November 1st, 2008 AT 2:09 AM
