1998 Dodge Neon anit freeze and oil leak
RIFSM1
  • 1998 DODGE NEON
My doge neon started leaking anti freeze now its leaking oil too I replaced the oil pan gasket and its still leaking. I cant find where the anti freeze is coming out at everyon says it might be the water pump sux anyone know whats wrong with it:
Wednesday, January 11th, 2006 AT 6:08 AM
ROBERT L VENABLE JR.
This happen to me after the oil pan gasket was replaced it was still leaking and it turn out to be the rear seal. See if you have signs of oil where the motor and transmission meet. If you do than there is a dust cover that can be remove by taken the bolts out. When this is done you will have oil that has collected there come out. If that happens than you can be sure that rear seal is leaking. You can check the coolant leaks by having a pressure check done.
Saturday, January 14th, 2006 AT 5:02 PM
WRENCHTECH
  • 20,761 POSTS
To find the coolant leak, what you have to do is pressure test the cooling system for whatever time it takes to see the leak and follow it to it's source.
As far as the oil leak is concerned, the oil pan is only one of dozens of places a car can leak oil and they usually leak in more that one place. Oil runs downhill and it is blown back. For this reason you have to find the highest point that you find oil and repair that leak first. Clean the engine and drive it to look for more leaks.
Tuesday, May 10th, 2011 AT 6:13 PM
CJ MEDEVAC
  • 11,005 POSTS
THIS IS SOMETHING A MUFFLER SHOP NEEDS TO REPAIR
LOOKS LIKE IT RUSTED ON THE PIPE AND BROKE
I DOUBT YOU HAVE A BENDER AND A MIG WELDER
SHOP AROUND ON THE PHONE, AND DRIVE IT NICE AND SLOW TO THE SHOP YOU SELECT. AS TO STAY AS QUIET AS YOU CAN BE
THE MEDIC
Friday, January 27th, 2012 AT 4:23 AM
CJ MEDEVAC
  • 11,005 POSTS
WELL THAT MESSED UP!
I WAS ON ANOTHER POST (FOR SURE!)---AND GOT TELEPORTED TO HERE!
SORRY!
GONNA LOOK FOR THE ONE I WAS ON!
THE MEDIC
Friday, January 27th, 2012 AT 4:25 AM
CJ MEDEVAC
  • 11,005 POSTS
OK----THIS IS JUST NOT OPERATING RIGHT---DID IT AGAIN!
SORRY AGAIN
THE MEDIC
Friday, January 27th, 2012 AT 4:27 AM
Open it up and investigate-switch could be defective needing replacement
Sunday, April 22nd, 2012 AT 1:55 AM
FIXITMR
  • 9,990 POSTS
Hahahaha. The lost and found department please.
Sunday, April 22nd, 2012 AT 2:07 AM
Lmao-this is not the thread I was answering it has to do with headlight-What's going on here
Sunday, April 22nd, 2012 AT 9:42 AM
CJ MEDEVAC
  • 11,005 POSTS
2CARBLACKHOLE
THE MEDIC
Sunday, April 22nd, 2012 AT 1:43 PM
RIVERMIKERAT
  • 6,110 POSTS
Well. This isn't where I parked my Caravan problem. :)
Thursday, May 31st, 2012 AT 9:53 PM
Back it up and then go down the street-hook a right on the stop, go further down a bit-take the 1st left turn -right on the corner ask the gas attendant where you at
Thursday, May 31st, 2012 AT 11:01 PM
RIVERMIKERAT
  • 6,110 POSTS
Any landmarks you can point out for me Raz? Apparently the GPS in this thing is broken.
Friday, June 1st, 2012 AT 2:04 AM
WRENCHTECH
  • 20,761 POSTS
I guess this question is the new broken link magnet.
Friday, June 1st, 2012 AT 2:06 AM
KHLOW2008
  • 41,814 POSTS
The guy is not a qualified electrician. You should NEVER disconnect the battery terminals when engine is running and you aggravated it by increasing the engine rpm.
The alternator produced a power surge that has fried the PCM. That is where you should be looking at.
Do you mean you have repaired the PCM and engine is running now but all the indicator lights are showing?
Friday, August 10th, 2012 AT 7:10 AM
RIVERMIKERAT
  • 6,110 POSTS
KHLOw, maybe, but maybe not. Not sure, since the car is somewhere in the US and I'm in SÃ o Paulo, Brazil. Lol
Friday, August 10th, 2012 AT 5:19 PM
KHLOW2008
  • 41,814 POSTS
Lol, have we moved to the Bermuda Triangle? Any of us can appear from nowhere.
Friday, August 10th, 2012 AT 5:21 PM
RIVERMIKERAT
  • 6,110 POSTS
Yep. Sure have.
Friday, August 10th, 2012 AT 5:29 PM
EXOVCDS
  • 1,883 POSTS
The fan is not blowing?
What color is the wire?
Using a test light, you can check for power at the fan switch and at the resistor pack (by the actual fan).
No power at the switch, then re-check the fuses. If you have power at the switch but not at the resistor pack, find the break in the wire(s).
The fan motor GROUND wire needs to be attached at the bottom right of the dash / chassis ground.
Too many variables to solve via a keyboard.
Thomas
Thursday, January 10th, 2013 AT 2:43 AM
