HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Engine
Symptoms
Oil Leak
1998 Dodge Neon oil leak
DARRELL DEE
MEMBER
1998 DODGE NEON
4 CYL
2WD
AUTOMATIC
89,000 MILES
Have an oil leak, seems to be sitting on tranny, were could it be coming from
Monday, June 9th, 2008 AT 1:55 PM
OBXAUTOMEDIC
MECHANIC
There are a couple possibilities one is the Valve Cover Gasket.
The other is the Cam Shaft Sensor if it is a Singe Overhead Cam (SOHC).
SPONSORED LINKS
Thursday, June 12th, 2008 AT 3:50 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1998 Dodge Neon Anit Freeze And Oil Leak
My Doge Neon Started Leaking Anti Freeze Now Its Leaking Oil Too I Replaced The Oil Pan Gasket And Its Still Leaking. I Cant Find Where The...
Asked by
rifsm1
1998
DODGE NEON
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
Oil Leak Between The Oil Pan And The Main Seal
Only When The Car Is Running Leaking Oil Pretty Bad. It Looks Like It Is Leaking Between The Oil Pan In The Main Seal. Pretty Bad Oil Leak.
Asked by
aaron1967
1 ANSWER
1998
DODGE NEON
1998 Dodge Neon Oil Leak
Hi, I Have A 1998 Neon. When I Got It It Had A Small Oil Leak. It Just Dripped Here And There, Would Be Fine Between Oil Changes For About...
Asked by
Killa
1 ANSWER
1998
DODGE NEON
1998 Dodge Neon Oil Leaks
1998 Dodge Neon I Have A Oil Leak And Im Not Sure Where Its Coming From Is It Going To Cost A Arm And Leg To Fix The Leak Isnt Bad.
Asked by
poptart
1 ANSWER
1998
DODGE NEON
1998 Dodge Neon I Have An Oil Leak And I Was...
I Have A 1998 Dodge Neon Just Bought It About Two Weeks Ago With 103.098 Miles On It And It Is Leaking Oil Like Carzy. I Have To Put In A...
Asked by
HEYSMACKTHSAZZ69
1 ANSWER
1998
DODGE NEON
VIEW MORE
SPONSORED LINKS
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Cylinder Head Gasket Blown Symptoms
Online car repair manuals
