1995 Dodge Neon 4 cyl Two Wheel Drive Manual 120k miles
I just broke the timing belt and put a new one in and timed it perfact. When I go to start it. It wont start unless I hold the gas peddel down then it whants to die. So I hooked it up to a derby and it sad every thing is fine but it showed map sencor. So I put a new one on and that did nit work. I then checked the wire harness and it is fine. What else could it be.
SPONSORED LINKS
Wednesday, July 16th, 2008 AT 9:21 AM
