1999 Dodge Durango No Bus Odometer
I own a 1999 Dodge durang SLT V8 Magnum with 61,000 mileson it.
My odometer displays after 15 seconds or so stops showing the mileage and then displays an error message "No Bus".Yet it continues to record the actual miles driven.What is the meaning of the message,what does it pertain?
Mar 10, 2007 at 9:22 PM
  • 110,248 POSTS
The no bus code indicates there is no signal from the computer to the item. I would make sure the wiring harnesses are tight and not damaged from the computer. Give the harness a shake to see if it changes anything.
Apr 3, 2009 at 3:46 AM
Suggested Repair
Check the wiring harnesses from the computer for tight, undamaged connections. Shake the harness to see if the No Bus message changes, which can indicate a loose or damaged connection.
Conversation Summary
The owner of a 1999 Dodge Durango says the odometer shows mileage briefly, then displays No Bus, while still recording miles. The expert explains that No Bus means there is no signal from the computer and recommends checking that the computer wiring harnesses are tight and undamaged, then shaking the harness to see if the display changes.
