1999 Dodge Durango Idle Surge and Stall
TDANWAL
I have a 1999 Dodge Durango with 113,000 miles, V8 5.2 engine. It idles up and down. It has a slow start and it feels like you're pulling a trailer and you're not. It cuts off frequently. You have to put the vehicle in nuetral so it won't cut off. The check gauges light comes on. It seems like the transmission is slipping. Can you help? I know dodge has a lot of problems with transmissions on their vehicles, I figure that some people have the same problems that I have. Do you know if they have had a recall for my vehicle. If so, I haven't been informed. Thanks.
Feb 19, 2007 at 4:14 AM
CHEVY22
  • 1,375 POSTS
no recalls would apply being that old , but if you have an engine light on have the codes checked before you replace anything
Feb 19, 2007 at 4:30 AM
KHAUTO
Sounds like you could use a tune-up. I had similar symptoms, changed plugs, wires,distributer cap and it runs great!
Feb 21, 2007 at 1:29 PM
Suggested Repair
No recall applies because of the vehicle's age. If a warning light is on, have diagnostic codes checked before replacing any parts.
Conversation Summary
The owner of a 1999 Dodge Durango with a 5.2 V8 reports surging idle, slow starts, frequent stalling unless shifted to neutral, a check gauges light, and a sensation of transmission slip, and asks about a recall. An expert says no recall applies at that age and advises scanning codes before replacing anything. Another owner reported similar symptoms improved after replacing plugs, wires, and the distributor cap.
