Fuse Box
JENMACK13
I have a 2004 Dodge Durango, and my pigtail for the trailer lights has quit working! I am pretty sure it is just the fuse, but when you look in the fuse box it only lists codes with no explanations as to which code is for what part of the truck! Can you please tell me which code is for the fuse for the pigtail?
Jul 2, 2007 at 9:07 AM
BULTERIER
There is a fuel relay switch that needs to be replaced. It is located on the passenger side floorboard to the right- kinda of hard to find- but it is there- bolted on with 1 10 mm blot. To ensure it is not your fuel pump- run a wire (12v) from battery to the fuel pump - can gain access through trunk- under a plate mounted with 4 -100 bolts- run the wire to the positive terminal ( there are two) and see if the fuel pump will work that way- if it does then it indeed is your fuel relay switch as I mentioned at beginining.
[quote:ed62db41a6="bigpedro36"]89 acura Legend V6L 170,534mi
Well it wont start because the fuel pump isnt getting any power from the battery. WE replaced spark plugs and the distributor cap any ideas on whats wrong ?[/quote:ed62db41a6]
Jul 10, 2007 at 5:15 AM
