Windshield Washers not working - 2002 Dodge Intrepid
CAPNTASTIC
The washers no longer work on my 2002 Dodge Intrepid. when activating the washers, there appears to be no reaction/sound from the washer motor. Thought maybe it was a fuse issue, but could not find a fuse associated to washers...only wipers.
Oct 30, 2006 at 4:14 AM
BRUCE HUNT
  • 3,754 POSTS
You should be able to check the connection to the pump and see if voltage is present when the call is made. If not, the fuse, and don't forget to look under hood for additional fuses, or the switch itself could be at fault.
Nov 1, 2006 at 7:35 AM
