Intrepid will not go forward in Drive????
SPARKIE100
I have a 1996 Dodge intrepid 3.something engine, and around 150,000 miles on it. The Check Engine light has been on since the day I bought it. I was told that the switch was bad and did not have the $600 to replace it. My husband recently took out the bulb for the light and I loaned the car to a friend. She reports to me that the car starts up fine, engine sounds good, drives in reverse great, but can't go anywhere in drive, to her it sounds like its stuck in 3rd gear and just dies. Anyone know of what the problem can be. Thank you so much for any help I can get.
Pam
Nov 26, 2007 at 8:13 AM
2CARPRO JACK
  • 11,533 POSTS
I can try...LOL. Can you see the brakes through the wheels? sometimes if a caliper bolt falls out it will only let the car roll forward. Worth a look. Otherwise if it rolls freely when in neutral engine off, it is most likely the trans...............
Nov 26, 2007 at 10:02 AM
SPARKIE100
We'll take a look at it and let you know in the morning.
Nov 26, 2007 at 10:09 AM
SPARKIE100
[quote:d0376a29b4="2CarPro Jack"]I can try...LOL. Can you see the brakes through the wheels? sometimes if a caliper bolt falls out it will only let the car roll forward. Worth a look. Otherwise if it rolls freely when in neutral engine off, it is most likely the trans...............[/quote:d0376a29b4]
Nov 27, 2007 at 5:00 AM
SPARKIE100
Checked this last night, the car does not roll forward, and the claliper bolt has not fallen out, could it be the Check engine switch? or any other suggestions. Although I am releaved that the transmission is still there.
Nov 27, 2007 at 5:03 AM
