CHECK ENGINE LIGHT, SPEEDOMETER IS BROKE
SANDERSO
1999 DODGE INTREPID, ABOUT 72,000 MILES,
HIGH RPM'S, SPEEDOMETER QUIT WORKING, CHECK ENGINE LIGHT ON & ALL AT ONCE AND RUNNING HARD, WHAT COULD BE WRONG?
Nov 1, 2007 at 1:36 AM
BMASTERJERRY
  • 47 POSTS
Driving a vehicle while it's missing can damage the catalyst convertor(s) which can run upwards of $1,000 each.
Try hitting a local AutoZone for a free scan and post your code(s).
They were common for a loose heater hose clamp leaking coolant on #4 cylinder (rear passager side) killing the coil and/or plug. Code P0304...
Aug 17, 2007 at 4:02 PM
GENE_MELFINA
  • 5 POSTS
Check codes by doing the key dance, and count the flashes coming from check engine light, and let me know. I have a 1997 intrepid, and the key dance works.
Nov 1, 2007 at 2:59 PM
