I'm no expert but first find what code is causing the check engine light. Any garage could use their code reader and tell you what the codes are. I don't know if they would charge a fee for this. I know tha Auto Zone will check it for free. You might even consider purchasing a code reader. They can range from about $50 for the ones you use your computer with to about $350 for the one that Auto Zone sells. After getting the cos=des then you can start trouble shooting. It could be any issue that goes to your emmisons.
Spark Plugs, spark plug wires and several different sensors. Start with getting the codes read.
As far as the vacuum leak, usually your car will idle at a higher RPM. You can also often hear a hissing sound under your hood as this is a vacuum leak sucking air. :D
Good Luck!
SPONSORED LINKS
Wednesday, September 19th, 2007 AT 3:01 AM
