2000 Dodge Intrepid how long will it take to replace a heater core
Dec 20, 2006 at 9:28 AM
Plan on about 8-10 hours for an experienced mechanic, and longer if you have not done this job. Access typically requires removing the entire dash. Use a factory service manual, since aftermarket manuals do not cover the fasteners.
The owner asked how long it takes to replace the heater core on a 2000 Dodge Intrepid. The expert estimated 8-10 hours for a good mechanic and longer for a first-timer, noting that the dash usually must be removed and that a factory service manual is needed.
