THERMOSTAT
DDHARRIS9
  • 2001 DODGE INTREPID
  • 6 CYL
  • FWD
  • 96,000 MILES
Need directions on replacing thermostat in 2001 Intrepid V-6 2.7liter
Sunday, January 5th, 2020 AT 1:26 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Drain coolant system
remove oil dipstick and tube. Cover the opening so nothing can enter in the engine throw it
raise and support the car
support the engine and remove left motor mount
remove alternator
remove lower heater hose from thermostat housing
remove housing
you may have to remove tranny dipstick bracket bolt
good luck
COLDSTEEL9MM
  • 21 POSTS
  • 1999 DODGE INTREPID
  • 165,000 MILES
Where is the location of the thermostat location on 1999 2.7L and how is it removed? Seen some web links that say its on the top of the motor in the middle and some others that say it's under the alternator.
SATURNTECH9
  • 30,869 POSTS
It says move aside the alternator to help. Access the thermostat.
COLDSTEEL9MM
  • 21 POSTS
That means I have to remove the serpentine belt as well? I'm in a hotel parking lot.
COLDSTEEL9MM
  • 21 POSTS
Also, the temp gauge never went above half way but steam was coming from under the hood.
Thermostat or water pump?
LITTLEBIT1234
Engine Cooling problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
WHERE IS THE THERMOSTAT LOCATED
Here's a thermostat location for a 2.7L and 3.2L engine:
https://www.2carpros.com/forum/automotive_pictures/12900_27t_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_32t_1.jpg
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
WRENCHTECH
  • 20,761 POSTS
Sounds like you have a leak. The system needs to be pressure tested and I seriously doubt you are going to repair thing in any parking lot.
SATURNTECH9
  • 30,869 POSTS
I. Agree with wrench tech sounds like.A. Leak. Was it the steam. Coming from. The. Cap. You might have a bad radiator cap.
WRENCHTECH
  • 20,761 POSTS
The thermostat on this one is a real bear. I don't see why he's changing anyway.
SATURNTECH9
  • 30,869 POSTS
I. Know doesn't sound. Like. It's even. Overheating.
MVELEZ
  • 1997 DODGE INTREPID
  • 6 CYL
  • 150 MILES
I have a 1998 dodge intrepid ES 3.2 and I need to know where the thermostat is located. Could u help me out with a diagram or something. Thanks
https://www.2carpros.com/forum/automotive_pictures/12900_t_4.jpg
The engine thermostat is located in a water box, formed in the front of the lower intake manifold. This thermostat has an air bleed located in the thermostat flange.
MGW419
  • 6 CYL
  • 109,000 MILES
I want to chane the thermostat, and I am not sure of it's location. I think it's on the upper house leading into the engine. That fitting seems to have a nipple on it. Do you know what that is also?
Thanks!
BMRFIXIT
  • 19,053 POSTS
Upper mid of engine
Follow upper radiator hose to engine and thermostat housing
make sure you bleed the system after thermostat replacement
good luck
DEMONHUNTER1200
  • 1995 DODGE INTREPID
M name is Ray and I just turned 16. For my bithday my parents gave me there old car. It has been running hot and I called around and found out I needed a thermostat. After buying one, no one on the block knows where it goes. I don't have the money to take it to a shop. My question is where does the thermostat go and does anyone know where I can find a diagram of the thermostat location that might help. Thank you.
Sunday, January 5th, 2020 AT 1:27 PM (Merged)
VANDRAGON
  • 298 POSTS
It is located at the end of the top radiator hose at the top of the motor, where the hose is clamped to the housing. Go to a parts store and ask if they have the time to come out to your car and show you where is goes and how to do it, other than that got to the store and look at a haynes manual. Please don't try to repair this without the motor being cold. Good luck
