2002 Dodge Intrepid spark plugs
79,000 MILES • 6 CYL • 2WD • AUTOMATIC
GUYMANDUDE
Where and how do you change the spark plugs on a 2002 Dodge Intepid
Mar 28, 2010 at 10:17 AM
  • 75,988 POSTS
REMOVAL
Always remove the ignition coil assembly by grasping at the spark plug boot, turning the assembly 1/2 turn and pulling straight back in a steady motion.
1.Prior to removing the spark plug, spray compressed air around the coil area and spark plug.
2.Remove electrical connector from ignition coil. On 3.5L engines, it is necessary to loosen the screws by alternating back and forth. Do not lose the spacers under the coil when loosening the screws.
3.Remove 2 fasteners from ignition coil.
4.Remove ignition coil assembly.
5.Remove the spark plug using a quality socket with a rubber or foam insert.
6.Inspect the spark plug condition.
INSTALLATION
1.To avoid cross threading, start the spark plug into the cylinder head by hand.
2.Tighten spark plugs.
2.7L engine 17.6 Nm (13 ft. lbs.)
3.5L engine 28 Nm (20 ft. lbs.)
3.Install ignition coil assembly onto spark plug.
4.Install coil screws and tighten.
2.7L engine 6.2 Nm (55 in. lbs.)
3.5L engine 6.7 Nm (60 in. lbs.)
5.Connect the electrical connector.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 28, 2010 at 10:45 AM
