2002 Dodge Intrepid
SAMFEWINS
  • 2002 DODGE INTREPID
Shakes or Wobbles problem
2002 Dodge Intrepid 6 cyl Automatic 133652 miles
my car had been chugging. When I do a rolling stop or not come to a compleate stop my car will sometimes start to chug, when it gets to about 20, 30 or 40 MPH. If I let off the gas it will stop, and if I keep pushing the gas it keeps going but will stop with in 20-30 secs. It has stoped running on me twice, when I was driving. The check engin light came on about 5-7 days before it started to chug. I was thinking that I was my fuel pump, or my spark plugs. I change the plug in november 2008 or 2007. The fuel pump has never been replace. Can you help me with what is going on with my car please.
thanks
sam
Tuesday, March 2nd, 2010 AT 10:06 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Wednesday, March 3rd, 2010 AT 12:29 AM
