2002 Dodge Intrepid
LISHAKEY2
  • 2002 DODGE INTREPID
Engine Mechanical problem
2002 Dodge Intrepid 6 cyl Automatic
I have coolant leaking into my oil, what could be the problem?
Friday, November 6th, 2009 AT 5:23 PM
CH112063
  • 1,320 POSTS
A cracked head or bad cylinder head gasket will do this. Bad intake gasket also and few other things but a heasd gasket takes care of most everything. Have it pressure tested with the plugs out and then disable spark system and see if a cylinder sprays out coolant. Ok Gotta crank it with the spark and injectors disabled. Ok If it has over 60, ooo miles they will go.
Friday, November 6th, 2009 AT 6:57 PM
TYLERLEO
Also could be bad water pump.
Wednesday, November 11th, 2009 AT 1:15 PM
CH112063
  • 1,320 POSTS
I hope not, which engine are you working with and what is the mileage? Have you seen it anywhere but in the oil? Either engine I hope it is not bad. The pump mounts on the front cover on one and the block on the other, either way is not very good for it to be leaking inside, maybe the block. Good luck.
Wednesday, November 11th, 2009 AT 9:16 PM
