2001 Dodge Intrepid
2001 DODGE INTREPID
160,000 MILES • 6 CYL • FWD • AUTOMATIC
JBLEHMAN60
I am losing oil and I feel that it is somehow leaking into the coolant. Which has turned to chocolate milk.Also there is no sign of coolant in the oil. No cross contamination.
May 10, 2009 at 4:24 PM
BMRFIXIT
  • 19,053 POSTS
Check tranny fluid
suspect bad tranny cooler inside the radiator
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 10, 2009 at 10:26 PM
JBLEHMAN60
I think it is oil not tranny fluid.The tranny fluid level stays constant plus the staining around the overflow tank does not look like tranny fluid it looks like oil. Also the oil level is always going down
May 11, 2009 at 12:13 AM
