2001 Dodge Intrepid WATER IN THE OIL
2001 DODGE INTREPID
99,000 MILES • 6 CYL • FWD • AUTOMATIC
JCAST56
WHAT NEEDS TO BE CHECKED AND CAN I FIX MYSELF
Apr 26, 2010 at 8:48 PM
TOOOMANYTOYS
  • 513 POSTS
I need alittle more explaination. Antifreeze in the oil? If so you need to do a block test to see if you have gas fumes in coolant. Block testers can be bought at most auto parts stores. If test fails you may need to remove heads to find out whats causing antifreeze to get in oil.
Apr 26, 2010 at 9:04 PM
