2002 Dodge Intrepid
ALLEY2002
  • 2002 DODGE INTREPID
  • 6 CYL
  • 115,264 MILES
After about 20 minutes, when slowing down transmission will down shift into first and will not shift out unless car is turned off restarted, also a P0700 code is set
Friday, January 2nd, 2009 AT 10:37 AM
  • 109,885 POSTS
The code P0700 will set for an internal Trans. Controler fault detected. "For any fault detected on a trans. This is the first code to set. After come the other ones.
If it come alone, you will need to make some test to determinate
If the TCM ( Transmission controler module) is fault or there are other problems.
Tuesday, January 6th, 2009 AT 10:46 PM
