2001 Dodge Intrepid wont start
CHARLIEP
  • 2001 DODGE INTREPID
  • 6 CYL
  • FWD
  • 113,000 MILES
This car is not getting fire hook up on a scanner said the crank shaft sensor so replace it and the car still wont start it gets fire every now and then but still wont sart put a cam button in still have the same problem so do you have a suggestion
Saturday, February 16th, 2008 AT 8:43 PM
BMRFIXIT
  • 19,053 POSTS
What engine you have in it (engine size)
check timing belt
check /replace ASD relay
when cranking using scanner read data
do you have a sync between crank and cam
let me know
Sunday, February 17th, 2008 AT 8:42 AM
