You have 4 bolts holding the latch, remove the bolts and the cable, and it will come out.also i,m sendding you picture of lift remove,just in case you need to, one day. you,ll need to have an assistant hold up the hood while you replace the lift,. most lifts have snap-on,ball and socket connections, some are held in place with bolts or clips.
SPONSORED LINKS
Saturday, October 24th, 2009 AT 11:41 PM
