2000 Dodge Intrepid Battery must be jumped to start
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
WYNNER
About 6 months ago I had the Alternator and Battery replaced in my son's car. It worked fine for a couple weeks and then started NOT starting on occasion. Son discovered If you shook the electrical wires connected to the battery, it would start. That worked for another couple months. Now it won't start unless it is jumped. Any ideas?
Dec 10, 2007 at 10:32 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
Start by having the battery load tested, and check the alternator charge rate, If by shacking the connections at the battery, something is loose or corroded and making a poor connection. Disconnect all wires & soak ends in a solution of warm water and bicarb soda, this will dissolve all the acid build up. Flush with clean water. check all connections and replace if any look suspect clean battery terminals and re attach all wires, coat with a anti fouling spray (battery terminal protector) and test system, Check starter electrical connections as well, include all earths too.
Mark (mhpautos)
Dec 10, 2007 at 12:34 PM
