1999 Dodge Intrepid Power
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
REDLINESPEEDSPORTS
battery can be charged up and won't start....just clicks. however, if i put jumper cables on it, it will start and run for about 10 miles. It is not the alternator as I spent numerous hours getting it out and having it checked. It seems as if it could be in the ignition not allowing the alternator to work?????
This 99 Intrepid has a 2.7 enigine in it.
I also have a sister car to this one and has started to knock and oil level has been maintained and doesn't blow smoke or even use oil??? What's up with my Intrepids?
Jul 9, 2008 at 5:46 AM
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:e28b48c766="redlinespeedsports"]Engine Mechanical problem
1999 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 150,00 miles
I also have a sister car to this one and has started to knock and oil level has been maintained and doesn't blow smoke or even use oil??? What's up with my Intrepids?[/quote:e28b48c766]
Ok, 1st car check and clean the negative battery connections, a bad ground can cause your problem with this one.
The 2nd car have oil pressure tested.
Post finding here in forum....
Jul 9, 2008 at 10:17 AM
REDLINESPEEDSPORTS
Ground post is extremely clean and tight........ruled out on first car.
On second car, oil pressure was checked out and runs at a normal pressure, both at higher rpms and idle.
Now what?
Jul 9, 2008 at 5:20 PM
OBXAUTOMEDIC
  • 3,717 POSTS
Did you check the ground connection on the block.
Can you tell if the knock is at the top of engine under Valve Cover or at the bottom oil pan.
If under valve cover more than likely it's the Hydrolic Lash Adjusters (Lifters)
Jul 11, 2008 at 6:53 AM
REDLINESPEEDSPORTS
Hi guys:
Problem on car 1 was a bad wire to the alternator. Also replaced the cam sensor.
Car 2: yes, the noise is under the valve cover, drivers side, top of engine. Do you think the valve lashes need resetting or is something broke?
Thanks for your reply.
Wayne
Jul 11, 2008 at 7:04 AM
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:25707b85a1="redlinespeedsports"]Hi guys:
Wayne[/quote:25707b85a1]
They are Hydrolic so there is no adjusting you will have to replace them. I recommend replacing all and not just the one or 2 that may be Colapsed.
Jul 11, 2008 at 7:15 AM
