1999 Dodge Intrepid No Drive After Wash
RATORREY
We just purchased this car with 60000 mile on it. 3.2 liter 4speed autostick transmission. My wife drove it through the car wash (had under carriage washed) and apon exiting the car wash and putting the vehicle in drive it would not move. She shifted between park and drive a couple times, is sure it was in a drive gear (no luck). Checked Ebrake (no luck) put the car in Reverse fealt what seemed like something engage or disengage and the car moved and appears fine. Her explanation to me was that it fealt like the right rear wheel was locked up. She stated she noticed what appeard to be a grease/oil smell coming from that wheel. I was not there and do not have any first had knowledge. Anyone have any thoughts? ABS locke up? Transmission glitch?? or general quirk?
Richard
Jan 4, 2006 at 4:54 AM
  • 55,746 POSTS
Sounds like you may have transmission or a transmission controller problem. :cry:
Jan 4, 2006 at 7:06 AM
RATORREY
Can you help me out here a little more? Before the undercarriage wash and even now after that one incident the transmission goes into gear properly and shifts smoothly no niticeable issues. What do you think happend with the under carriage wash? Something get wet? Something stick? Are you saying that it appears the transmission did not know it was being shifted into a gear?
Jan 4, 2006 at 7:13 AM
  • 55,746 POSTS
I dont think the under car wash would hurt it. It is almost water proof. Scan the PCM to check for trouble codes.
Jan 4, 2006 at 9:22 AM
Suggested Repair
Scan the PCM for trouble codes. The undercarriage wash is unlikely to have caused the no-drive incident because the transmission is largely waterproof; a transmission or transmission controller fault is the more likely concern.
Conversation Summary
A 1999 Dodge Intrepid ES with a 3.2L and 4-speed Autostick would not move in Drive after an undercarriage car wash, though Reverse seemed to engage something and the car then drove normally. The driver also felt the right rear wheel may have locked and noticed a grease or oil smell. The transmission otherwise shifts smoothly. The expert said the wash was unlikely to cause damage and recommended scanning the PCM for codes, suspecting a transmission or transmission controller problem.
