1999 Dodge Intrepid
COHOWE9
  • 1999 DODGE INTREPID
  • 6 CYL
  • 170,000 MILES
I own a 99 dodge intrepid. The codes that came thru were P1684, P0340, P0118, P1490 I found all of these codes but one P1684. The problem I am having with this car is that it will run for about 10 miles and then it dies and won't start for a couple of hours. The last time it done this now it won't start at all. It always took a while for it to start but now it won't start and how hard will it be to change the camshaft position sensor. Thanks for any help.
Saturday, December 29th, 2007 AT 10:39 AM
BLACKOP555
  • 10,371 POSTS
The P1684 is a battery disconnect code, it stays on for 50 car starts and it should clear away itself, unless your constantly loosing power.
I wouldnt suggest you change the cam sensor yourself, as it will have to go through a relearn procedure anyways, take it to the dealer
Saturday, December 29th, 2007 AT 11:37 AM
COHOWE9
Thank you for the reply. I was hoping that it would be something I could do on my own. Have you heard a lot about engine sluge in these cars. And does this car have a cabin filter? Every time we turn on the a/c or the heater it gives of an awful smell.
Sunday, December 30th, 2007 AT 8:59 AM
BLACKOP555
  • 10,371 POSTS
It could be the cabin air filter. If it smells like antifreeze its the heater core, try spraying bleach water in the blower motor housing hten turning on the blower
Sunday, December 30th, 2007 AT 9:15 AM
