1997 Dodge Intrepid 154,000 mi. This car was running fine then one day it started to run like it was running on four cylinders in stead of six. The check engine light came on so I took the car for a diagnostic check up the computer came back with a message of number 2 misfiring. Mister mechanic said to change the spark plugs and if these doses not work then change the plug wires and if this does not work then change the coil, well I went one step more and also change the fuel filter.
To no avail none of the above has solved my problem and now I have to drive with one foot on the gas and one foot on the brake to keep the car from stalling out on me. Can you help me before I take this car to a dealer? I check the codes and they are 12, 32, 43.
Feb 16, 2006 at 7:45 AM
