1996 Dodge Intrepid wont start.
LILSMILEY380
  • 1996 DODGE INTREPID
  • 6 CYL
  • FWD
  • 156,000 MILES
I have a 1996 dodge intrepid that wont start after replacing the water pump. I checked to see if there was current going to the spark plugs and there was none, what can I check for to make it work.
Tuesday, August 11th, 2009 AT 7:47 PM
BMRFIXIT
  • 19,053 POSTS
Did it start and run before the water pump replacement
check timing
check fuses and relays
do a code check
Tuesday, August 11th, 2009 AT 7:57 PM
LILSMILEY380
  • 5 POSTS
Yea the car did work before the water pump replacement but even before the pump replacemen sometimes the car wouldnt start due to no current going to the spark plugs I would have to wait like 2 hours so the car would work and yea the timing is good what else could b the problem.
Tuesday, August 11th, 2009 AT 8:01 PM
BMRFIXIT
  • 19,053 POSTS
At this point I would suspect crank sensor and or ASD relay
Tuesday, August 11th, 2009 AT 9:05 PM
LILSMILEY380
  • 5 POSTS
Hey I took a look at the crank sensor and it looks like it need to be replaced and the wires need to be cleaned cause they have alot of dry oil how can I remove it the easy way cause their is so little room to get to it?
Tuesday, August 11th, 2009 AT 11:16 PM
