1996 Dodge Intrepid WONT START
17,500 MILES • 6 CYL • 2WD • AUTOMATIC
GODFATHER2009
MY CAR WONT START I REPLACED THE ALTERNATOR 2 TIMES (AND ONCE AGAIN JUST RECENTLY (3 TIMES NOW)), HAD NEW FUEL PUMP REPLACED LAST YEAR, NEW BATTERY JUST LAST WEEK. WHEN I TURN THE KEY IT JUST CLICKS ONCE, AND DOESN'T TURN OVER. I WAS THINKING IT MAY BE THE STARTER ( I TRIED TAPPING IT BUT STILL NO RESULTS) HOW WOULD I KNOW IF THATS THE PROBLEM ? I ALSO CHECKED ALL THE FUSES NONE ARE BLOWN. I DONT KNOW WHAT ELSE IT COULD BE . PLEASE HELP .I GREATLY APPRECIATED. THANK YOU.
May 26, 2008 at 6:57 AM
MERLIN2021
  • 17,250 POSTS
f you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good!
May 26, 2008 at 7:02 AM
