1996 Dodge Intrepid dont know
DRACOSEYES
Transmission problem
1996 Dodge Intrepid V8
i have a 96 intrepid and i just changed out the starter.i took it out for a spin and its not shifting right.what could be the problem?i checked the fluid and its only a bit low not much just a bit.help!!!!!!!!!! plz
Nov 18, 2008 at 9:19 AM
  • 31,937 POSTS
Hi there ,
If the oil level is OK, i would get a transmission specialist to test drive and report for you, as you do really need to feel what the transmission is doing, you may just have a blocked filter or sticky shift valve, there will be a few tests that can be done to determine the exact cause of this problem.
mark (mhpautos)
Nov 18, 2008 at 9:58 AM
