1996 Dodge Intrepid car won't start
DARRYL BUCHANAN
  • 1996 DODGE INTREPID
  • 6 CYL
  • FWD
  • 146,000 MILES
Car doesn't show any signs of getting fire.
Saturday, August 21st, 2010 AT 4:33 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Saturday, August 21st, 2010 AT 5:33 PM
