HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Brakes
Wheel Cylinder
1994 Dodge Intrepid
CACHE
MEMBER
1994 DODGE INTREPID
Engine Mechanical problem
1994 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
Sounds like the engine is going to start, but it doesn't. What could be?
Sunday, April 25th, 2010 AT 5:30 PM
LEGITIMATE007
MECHANIC
Sounds like a fuel problem but it would be best to verify fuel and spark
Wednesday, April 28th, 2010 AT 2:24 PM
LEGITIMATE007
MECHANIC
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Wednesday, April 28th, 2010 AT 2:25 PM
LEGITIMATE007
MECHANIC
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Wednesday, April 28th, 2010 AT 2:26 PM
Please
login
or
register
to post a reply.
Related Wheel Cylinder Content
Some Times Cuts Off When Mashing Brakes?
Going Down The Road, Slow Down To Turn And Mash The Brakes The Car Will Cut Off, Not All The Time. What Can I Do To Fix This, Thank You
Asked by
clebo69x
1 ANSWER
7 IMAGES
2000
DODGE INTREPID
GUIDE
Wheel Cylinder Replacement
A brake system wheel cylinder is used to push against a set of brake shoes to help stop the car.
1995 Dodge Intrepid Bleeding Brakes
Brakes Problem 1995 Dodge Intrepid 6 Cyl Front Wheel Drive Automatic I Have Replaced The Caliper On The Right Rear Wheel, And Can't...
Asked by
steak63
1 ANSWER
1995
DODGE INTREPID
2000 Dodge Intrepid Brake Air Escaping
2000 Dodge Intrepid. Sounds Like Air Escaping When The Brake Pedal Is Pushed And When Its Cold. Do I Have A Leak In The Brake Booster? If So...
Asked by
jbgd3255
1 ANSWER
2000
DODGE INTREPID
Is My Brake Booster Bad
When I Push On My Brakes I Here Air And Its Hard To Stop Car
Asked by
ron burlingham
1 IMAGE
1993
DODGE INTREPID
2003 Dodge Intrepid Break Fluid
If Brakes Are Performing Great, Why Does Service Tech Say Brake Fluid Looks Dark ( From Heat) And Should Be Replaced. Says The Same Thing...
Asked by
Harvey Cutting
1 ANSWER
2003
DODGE INTREPID
VIEW MORE
Brake Shoe and Drum Replacement
Bleed and Flush Your Brake System Correctly
How to Bleed and Flush Your Vehicle Brakes
