2003 Dodge Intrepid Break Fluid
50,000 MILES • 6 CYL • FWD • AUTOMATIC
HARVEY CUTTING
If brakes are performing great, why does service tech say brake fluid looks dark ( from heat) and should be replaced. Says the same thing about power steering fluid.
Jul 15, 2009 at 9:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for the donation!
Although the components may be working properly NOW, that doesn't mean they will continue to work properly without proper maintenance. Replacing the fluids will prolong the life of your vehicle's power steering and brake system. Same for the engine and transmission. You should have the engine oil and transmisison fluid inspected and replaced on a regular maintenance schedule
Jul 15, 2009 at 3:46 PM
