1992 Dodge Dynasty Heater Not Blowing Warm
JAS21871
Driving down the road my heater stopped blowing warm air! I checked all the fuses and none were blown. Where is the heater blower located on a 1992 Dodge Dynasty 6cyl.?
Dec 4, 2006 at 8:50 AM
GARFIELD
  • 197 POSTS
You should be able to get to your heater blower motor under the passenger side of the car under the dash. Disconnect the connector from the fan, turn on ignition key to the on position and test the connector for voltage, if there is voltage then the problem will be in the motor. If it has no voltage then it will be in the blower resistor, switch or wiring.
Dec 5, 2006 at 9:18 PM
Suggested Repair
Access the heater blower motor under the passenger side of the dash. With the ignition on, disconnect the fan connector and test it for voltage. If voltage is present, the blower motor is likely faulty; if not, check the blower resistor, switch, and wiring.
Conversation Summary
The owner of a 1992 Dodge Dynasty reported that the heater suddenly stopped blowing warm air and that the fuses were not blown. The expert said the blower motor is under the passenger side of the dash and advised testing the fan connector for voltage with the ignition on. Voltage points to the motor; no voltage points to the blower resistor, switch, or wiring.
