1993 Dodge Dynasty No Fuel Delivery
JOYFUL
My car died while driving it. The fuel pump and filter attached has been replaced. There is no gas coming through the gas line. Starter fluid was used to check the gas flow. It started but died again. What gives?The engine is a 3.3 and the mileage is 1981964
Mar 20, 2007 at 1:13 PM
  • 75,988 POSTS
[quote:ba67f8dafc="joyful"]My car died while driving it. The fuel pump and filter attached has been replaced. There is no gas coming through the gas line. Starter fluid was used to check the gas flow. It started but died again. What gives?The engine is a 3.3 and the mileage is 1981964[/quote:ba67f8dafc]
Try the ASD relay it powers the fuel pump and comeback. NOTE: The PCM/ECU/ECM etc energizes the relay before it gets back there.
Mar 20, 2007 at 6:50 PM
Suggested Repair
Check the ASD relay, which powers the fuel pump. The PCM energizes that relay, so confirm the relay and its control before further fuel-system work.
Conversation Summary
A 1993 Dodge Dynasty with a 3.3 engine died while driving. The fuel pump and filter were replaced, but no fuel reached the gas line; starter fluid made it run briefly, then it died again. The expert advised checking the ASD relay that powers the fuel pump and noted that the PCM energizes the relay.
