1990 Dodge Dynasty Stalling
TIM WHITEHEAD
Hi I have a dodge dynasty LE 1990 3.3 V6 200,000 kms. She keeps stalling after a while and is sometimes difficult to start. When in Park or neutral she will run for hours most times. When running in drive she will go for for a while and then cut out. I have replaced the gas pipes, fuel filter, pertol pump relay, checked the Vac hoses to no avail. Could it be the idle speed as she idles at different speeds when in P,R,N and D. I have not checked the idling sensor as yet. PLease help as this is becomming very frustrating and time consuming. Many thanks
May 23, 2007 at 8:17 PM
E40WATER12
  • 522 POSTS
No check engine light on?, I would take a look at youre IAC sensor, Thats a common thing to cause youre car to stall, Sometimes the the little pin needle gets carboned with gunk, idle doesnt work properly, You could also try and clean out youre TCC sensor or speed sensor.
May 23, 2007 at 8:51 PM
Suggested Repair
Inspect and clean the idle air control (IAC) sensor, especially carbon buildup on the pintle that can disrupt idle. Also clean the torque converter clutch (TCC) sensor or vehicle speed sensor.
Conversation Summary
A 1990 Dodge Dynasty 3.3 V6 stalls after driving and can be hard to start, though it often runs for a long time in Park or Neutral. Fuel lines, the fuel filter, the fuel pump relay, and vacuum hoses were already checked. The expert suggested inspecting the IAC sensor for carbon buildup and cleaning the TCC or speed sensor.
