After highway driving the car stalls when foot is taken off the gas.
1993 DODGE DYNASTY
172,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
SHAKER340
  • 8 POSTS
After highway-speed driving the car stalls on the exit ramp as soon as foot is off the gas pedal. Check gauges light comes on. Oil pressure goes to zero. Car starts back up but the RPMs need to be kept up to keep engine running. Around town in short distances the car seems to run fine, no stalling, good idle. Has good battery, new gas filter, new PCV, new EGR valve. Today I got the car home and tried to restart it while engine was still warm, it didn't want to start. Pumped gas pedal a couple times, it started- then I had to keep the RPMs up to keep it running. Please advise. Thanks.
May 1, 2014 at 2:42 AM
HMAC300
  • 48,601 POSTS
scan fr codes and check fuel pressure with a gauge autoparts rent it. shold be 46-48 psi w/vacuum hose connected to regulator and 55 without
May 1, 2014 at 3:03 AM
SHAKER340
  • 8 POSTS
Haven't had a chance to follow up on your suggestion yet but in checking further I found a 15 inch section of wires in sheathing that had broken off completely and tangled around the axel. The two wires are black with a thin blue stripe and dark green with a thin orange stripe. I appears that this section was connected originally to a line off the power steering pump? The car has had no steering issue. I've been looking all thru my repair manual to try to identify this in case it is a sensor that is affecting the stalling. Any idea what those color wires are used for? Thanks.
May 1, 2014 at 5:33 AM
SHAKER340
  • 8 POSTS
Found the color of the one wire is Dk Blue with orange, not green as I first thought. The manual says it belongs to the power steering pressure switch. Would this affect the stalling? What does the power steering pressure switch do? Do I need to repair/replace it? Thanks
May 1, 2014 at 5:41 AM
HMAC300
  • 48,601 POSTS
there is a dark blue with orange that runs off the power steering pump switch on one side and the black with blue line goes to other side of switch but it also goes to the coolant temp, throttle body etc. so fix that first it may solve your problem.
May 1, 2014 at 5:42 AM
HMAC300
  • 48,601 POSTS
yes you will need to fix it but you will have to see where it tied in to begin with . the power steering switch raises idle when you go to lock on the steering but because other switches are connected that has to be fixed as well.
May 1, 2014 at 5:44 AM
SHAKER340
  • 8 POSTS
Made a connector, spliced the broken wires to the computer on one end and repaired and connected the connector end going to the power steering pressure switch. Now the car still doesn't idle well. Engine runs rough. Is there anything that needs to be "re-set" I don't dare drive it as it will keep stalling. HELP!!! Thanks.
May 5, 2014 at 6:56 AM
HMAC300
  • 48,601 POSTS
do what I said in first reply also check for a vacuum leak.
May 5, 2014 at 8:06 AM
SHAKER340
  • 8 POSTS
No fault codes now (Had #25 & #52 before changing 02 sensor) Fuel pressure 50#. No vacuum leaks found. Replaced idle control motor, 02 sensor, cleaned the throttle body with carburetor cleaner as it was varnished up. When I disconnect any vacuum line from the intake manifold the RPMS increase. The car is running rich. When I stop the car with the brake it idles so slow the voltage drops to 12v on the gauge and the car quits. If the car is in neutral it idles, but a little rough. The engine runs great if the rpms are up. What do you suggest at this point?
Thanks.
May 19, 2014 at 2:30 AM
HMAC300
  • 48,601 POSTS
check compression also have you fixed th broken wires yet? and are they soldered or just twisted together. Like I said in first replay fix the whole harness first then check things out it can have an effect on engine running. Also make sure battery is in good condition including load test autoparts do for free and have clean terminal ends as well as a tight belt for alternator.
May 19, 2014 at 2:43 AM
SHAKER340
  • 8 POSTS
I have completed all your previous suggestions. The car is idling better, but still idles down close to stalling when I stop and add vacuum load by applying the brakes. The RPM's recover, but very slow. Can I manually adjust the RPM's at the throttle body without causing a problem? What should the RPM's be? How do I connect a Tach/Dwell meter to an electronic ignition car? The car seems to idle better after I get it out on the highway for a while. Is it possible that the computer is retraining?
Jun 8, 2014 at 4:49 AM
HMAC300
  • 48,601 POSTS
you can't set the idle the computer does but try cleaning throttle plate on both sides and iac hole with choke cleaner they get gummy and do what you are talking about.
Jun 8, 2014 at 8:42 AM
SHAKER340
  • 8 POSTS
Thank you for the response. I have already removed and cleaned the throttle body and all the ports and chambers. I replaced the IACM, tested the throttle position sensor, temperature sensor, coil pack, fuel filter, PCV valve, EGR valve, O2 sensor, plug wires and spark plugs. I changed any suspect vacuum hoses. How can I check to see, how low the RPM's are dropping? What should the idle RPM's be? Thank you.
Jun 8, 2014 at 10:52 AM
HMAC300
  • 48,601 POSTS
what's the fuel pressure like I asked many replies ago
Jun 8, 2014 at 11:33 PM
SHAKER340
  • 8 POSTS
Fuel pressure is 50 lbs.
Jun 9, 2014 at 12:58 AM
HMAC300
  • 48,601 POSTS
all I can tell you is torescan for codes now that the wiring is fixed and car is running straight. you can check vacuum at idle and normally a scanner wil pick up what the rpm is. if vacuumis 15' or below check for clogged exhaust . you can also check compression see if you migh thave a head gasket problem. or have cooling system pressure checked as well. other than that I'm out of ideas and have no further suggestions.
Jun 9, 2014 at 2:32 AM
