2004 Dodge Durango Fan clutch replacement
2004 DODGE DURANGO
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
JLACEY30
I replaced my fan clutch with a new one and there's a loud howling noise coming from the engine when I accelerates the gas.When it reaches 50 mph then it stops for a few mintues and starts again. What is the problem?
Apr 24, 2010 at 8:34 AM
  • 110,244 POSTS
The noise you hear is the fan spinning fast than you heard before. The clutch is sensitive to temp. The hotter the under hood temp is, the faster it spins the fan. Once things cool down, the noise will go away because the fan slows down.
NOTE: It isn't odd to hear it on first start up and then have it quiet down after about 1/4 mile.
Jun 8, 2010 at 3:20 AM
