2002 Dodge Durango fan clutch
2002 DODGE DURANGO
118,000 MILES • V8 • 4WD • AUTOMATIC
TONYJOHNSON
mechanic said fan clutch was bad. i can spin fan with my hand. mechanic said it was not spinning fast enough to cool engine thats why its running hot. is this a difficult repair? im no expert but i have replaced radiators, in tank fuel pumps, brakes,etc. i just want to be sure that there is something i should know before i attempt it.
Oct 13, 2009 at 10:47 AM
  • 110,240 POSTS
The worst part to replace it is to get the nut loose that holds the clutch to the waterpump pulley.
I recommend removing the fan shroud to gain access. Here is my trick. Do not take off the belt. Wedge a couple screwdrives under the pulley between the pulley and the water pump to help prevent the pulley from turning. Next, get a large cressent wrench and fit it tightly on the nut (fan clutch). Take a dead blow hammar and smack the cressent wrench counter clockwise. It usually takes about 5 or 6 hits, but then the nut will come loose.
They make tools to do this, but I have yet to find one that works.
Oct 20, 2009 at 4:22 AM
